Is there a CLI reference guide for ZF7372 AP?
I can't find anything in the technical documents section. There are several CLI guides for ZoneDirector and FlexMaster. But I'm looking for a guide for an 7372AP in a standalone mode. I also tried to search "CLI", but there was no results. Could you please provide a link.
Hi
I doubt about any CLI guide for standalone AP however while in CLI mode, if you type command "help" then it will give you all commands for use.
I made a copy of all those commands in word document for easy search.
Hope it helps.
I did the same, but then I found a pdf with all the cli commands in the Documents of the support page, that turned out to be the same.
I did the same, but then I found a pdf with all the cli commands in the Documents of the support page, that turned out to be the same thing.
Hi, Ed!
What was the filename or the name of the document?
For Toomas who Liked my comment above... We do support Solo/Standalone AP version CLI commands (more or less) versus
and AP that was SZ or ZD managed and then factory defaulted. So explore the commands available under the CLI if you run a
version like 104.0.0.0.1347 for the 7372, the AP model this question was originally asked about (two years ago, before 104.x was out)
https://support.ruckuswireless.com/software/1017-zoneflex-solo-access-point-104-0-0-0-1347-ga-softwa...
https://support.ruckuswireless.com/documents/1137-zoneflex-indoor-ap-104-0-user-guide
Thank you for supporting Solo/Standalone AP version CLI commands.
Why dont you make a command references?
