ZoneDirector
Is it possible to schedule a complete shutdown and a wake up for AP's?
I know i can schedule each WLAN to shutdown but not the AP it self. If this is not possible, i have the workaround that i time my Switch port to shutdown and wake up.
Thanks for your Help
cordelia_cordel
Hi Sandro,
I'm just the moderator here, but I did see this thread
https://forums.ruckuswireless.com/ruc...
-- not sure if this will help, let me know. Otherwise, many of our SMEs will be back from the US holiday tomorrow, and someone will get to you.
Cordelia
Hi Sandro Petruzzi
AFAIK, there is no way at this time to do auto shutdown and wakeup of AP as we do with WLAN schedule.
Curious to know why you are looking for this? Security? saving power?
If there is a real and useful business case then probably you need to be in touch with your regional system engineer to consider it and take it to product team.
Cheers.
Thank Cerdelia, sadly not works for me.
Hi Monnat,
the WLAN schedule i have integrated in my project but that's not enough for my Costumer. It's a Hotel and during the night-time he don't wanna electrosmoke, and he will see that's the lights on the AP's turns off and no signals came from the AP's. I know you can turn off this lights but not time scheduled...
So i think that would be enough to can turn off the lights of the AP during scheduled time. In other ways you have great Productsè
Best Regards from Switzerland
As with Monnat's reply I cannot see a way to auto shutdown/reboot on schedule for individual APs.
If they are POE and your switch allows for POE by timer then that would work.
Isn't the scheduled WLAN good enough as that kills the wifi coverage very effectively and can be done in 15min increments. Perhaps you are trying to stop use in a certain area while allowing others on the same WLAN to continue uninterrupted. Just speculating.
A total shutdown of the AP could be possible with a time managed PoE port switch,
you can enable/disable WLAN services by time period, and you know that you can
turn off the LEDs entirely if you wish to hide the APs function (often required by
hospitals and some hospitality). But to schedule the time LEDs are enabled or not
would require a Field Request to make a software change to accommodate the
feature that is not available in code today. You can provide your customer business
use case to your VAR or Ruckus account representative, to submit the FR on your
behalf.
