Possible to use PoE injector instead of AC adapter for T710 in mesh mode?
Need to power multiple T710 to use in mesh mode.
Don’t have 4-pin AC adapter, but do have correct PoE injector. Can I use injector without data input to power T710 and use in mesh mode?
i would say, yes, why not.
we do it on ZF7363
why you dont just try?
In all cases that support Mesh, ZoneDirector, SmartZone, and Unleashed, I recommend to connect and fully configure your intended Mesh APs before deployment in their desired location, and then you should have no problems (using power injector only).
