How to t300 first setting?
i find t300 software ,T300_200.7.10.2.339/OutdoorAP-100_1_0_0_432 , etc.
But I don't know where is the 'bl7' file open wizard.
I will connect router or herb by T300
please help me...
Ankush_Chandan
Hi JunUK,
Can you confirm if this will be a standalone AP or will be managed by ZoneDirector or SZ?
-Ankush
I have a 'OutdoorAP-100_1_0_0_432' zip file.
but inside of zip file, all files 'BL7'
maybe download another file....
Ankush_Chandan
If you are setting it as a standalone AP, APs are preloaded with firmware and you can set it up bu logging into its default IP 192.168.0.1 and default username and password (super / sp-admin). However if you want to upgrade the image of the AP, you can use following image:
https://support.ruckuswireless.com/software_downloads/1731-zoneflex-solo-access-point-110-0-0-0-675-...
Instructions on how to setup ap can be found under :
https://support.ruckuswireless.com/documents/2405-ruckus-outdoor-ap-110-0-user-guide/download
-Ankush
Hmm... take a t300 operation by POE.
POE output-T300/POE-input-my computer
Ethernet connect success but no internet
And use any borwser typing 192.168.0.1 but 'do not connect this site' logo on display.
I know Reset button inside of PG connect.
