hello guys, i encounter the same issue in several ocations with new aps and old aps trying to conect to vscg or scg this happend with older versions of the ap, you can patch the controller and you still had the same issue, i found the work arround /luckly/ well , u have to set the ap on unleash firmware then upgrade to solo ap and u resolve the booting issue ..try it!
