What is the latest Unleashed firmware I can run on a R500 AP? I have a combination of R500 and R510 APs throughout the building and understand the limitation noted above?
Hi Eugene,
Unleashed 200.7 is the final version to support the R500 platform. It also supports R510, so sounds like this is the ideal version for you.
HTH,Darrel.
Thanks, just updated the APs to 200.7.10.202..127 and everything runs great.
The Unleasehed Admin/Upgrade tab suggests upgrading to 200.8.10.3.290 firmware version even though I have a mix of the R500 at EOL and the 510. I will plan at staying on the 200.7 release.
