ZoneDirector
Unable to create WLAN using snmp v 3
I am unable to create WLAN using snmp v 3. I am using PHP. Although I have passed all the fields in the ruckusZDWLANConfigTable table and my functions are returning true still the wlan is no being created. any suggestions ?
keith_redfield
Please provide the version of software you're testing against. Thx.
Hi Keith ,
I am using PHP version 5.3.3. The device information is as follows :-
Ruckus wireless ZoneDirector
Software version is 9.5.2.0 build 15
Hardware Model Ruckus Zoneflex no 7372
any updates guys ?
keith_redfield
There are no open bugs on this, but it's also possible (likely..) you are the only person on the planet trying this. I'll email you offline if you want to send me your code we can try to re-produce/
Thanks Keith, I have mailed you the details. Someone has to start
Have you tested the code in your lab ? Any updates .
keith_redfield
No, I will contact you offline when someone can get to it. This is a low priority P4 issue. If you have a support contract and need to escalate the priority for business reasons, please open a support case.
