@leofan1126 was this resolved?
Was this resolved? I am also seeing the switch is disconnected but the internet is working in android phone and windows laptop but not with iphone and macbook .
Does anyone have any ideas?
I had the same issue last time as well. My lennar people replaced the switch and then worked fine. Even it was showing online when it was working on iphone and macbook.
Here is the image
I have same issue after power outage last night. For others in the neighborhood, it worked when they power cycled the switch but mine still unreachable. Should I open a support ticket?
@kiran_cheedalla Open support ticket. They will set the primary boot and secondary boot. They will copy primary memory to secondary memory something like that using some commands. Someone posted in another thread about those commands but we would have to take console of switch and then run those commands. Better to open support ticket.
Thanks,
Om
did you resolve this issue? i have the same exact problem with the iphone aswell
Is this issue ever resolved for you? Can you help with the steps that you performed to resolve?
wow you're lucky! I requested a replacement to simply fix my similar issue and they sent me a complicated method to fix it myself instead.
No, they will copy paste a complicated response that no one can follow and then hide behind their key boards until you go away.
