I want to know "AP Restart : power cycle" cause
Hi everyone,
My ZD 3000 was connected with 50 AP ZF 7372. It was not stable. When i check the debug log i found out following. Please suggest me what those mean and how can i fix it.
Aug 23 18:42:29
WLC01 syslog: eventd_to_syslog():AP[L1AP6@2c:5d:93:3c:1f:a0]
detects interference on radio [11g/n] and switches from channel [7] to
channel [9].
Aug 24 07:55:19 WLC01 syslog: eventd_to_syslog():AP[L1AP6@2c:5d:93:3c:1f:a0] heartbeats lost
Aug 24 08:15:07 WLC01 syslog: eventd_to_syslog():Lost contact with AP[L1AP6@2c:5d:93:3c:1f:a0]
Aug 24 08:19:21 WLC01 syslog: eventd_to_syslog():AP[L1AP6@2c:5d:93:3c:1f:a0] joins
with uptime [67] s and last disconnected reason [AP Restart : power
cycle]
Aug 24 08:19:24 WLC01 syslog: eventd_to_syslog():AP[L1AP6@2c:5d:93:3c:1f:a0] cold boot successfully
Aug 24 08:19:24 WLC01 syslog: eventd_to_syslog():AP[2c:5d:93:3c:1f:a0] is online.
Aug 24 08:35:15 WLC01 syslog: eventd_to_syslog():AP[L1AP6@2c:5d:93:3c:1f:a0] heartbeats lost
Aug 24 08:35:40 WLC01 syslog: eventd_to_syslog():AP[L1AP6@2c:5d:93:3c:1f:a0] joins
cycle]
andrea_coppini
A 'power cycle' is a power off/power on of the AP. In other words, someone or something removed electrical power from the AP, usually by unplugging it.
If this is powered via POE - check your switch
If this is powered via a local DC power supply, check your power outlet
Actually, whenever an AP loses contact with the ZD, it restarts. The default setting is 10 minutes I believe. So, what you need to figure out is why the AP is losing its connection with the ZD.
Update: If an AP loses connectivity, the message I see is "AP Restart: Network unreachable reboot", not the "power cycle" you see.
but there is no connection failure between when test ping with zd from ap. any idea?
andrea_coppini
That is impossible, you might be pinging the wrong IP. The AP rebooted so there had to be a minute or so of disconnection for sure.
As I said, if it's powered by POE, check the logs of the switch and also test the cable. Make sure it's not longer than 60m if CAT5/E or 80m if CAT6
A 802.3af PoE port delivers 15.4W and is meant to be able to deliver at least 12.95W of power to the end device.
Also if you are running a longer cable, you can use the Microsemi PoE extender to increase your cable run up to 500m:
http://www.microsemi.com/products/poe-systems/poe-extender
Increase the heartbeat timeout value to the AP to be something like 30mins.
When the network is under load the heartbeat to the AP can get lost and if the AP is constantly busy it will reboot based on your settings.
thanaphom
What causes "AP Restart: power cycle detected"?
