I purchased my Lennar home in 2019, which came equipped with a Ruckus ICX 7150-C12P switch and two ceiling-mounted Wi-Fi access points, one upstairs and one downstairs.
Around October 14, 2026, the Ruckus system stopped functioning properly, resulting in reduced Wi-Fi coverage throughout my home and connectivity issues with several smart-home devices.
Current issues:
- The switch has a solid green PWR light and solid amber SYST light.
- Both ceiling-mounted access points are completely dark and appear to be receiving no power.
- My Xfinity gateway and internet service are still working, but the Ruckus switch shows as offline in the Xfinity app, last connected October 14.
- The Ruckus Unleashed app cannot connect to the system.
Troubleshooting already completed:
- Power-cycled the switch and networking equipment.
- Performed the recessed reset procedure while reconnecting power. The LEDs flashed amber, but the switch returned to the same condition.
- Disconnected and reconnected Ethernet cables to verify connections.
- Checked the Xfinity and Ruckus Unleashed apps, but the switch remains offline.
Based on these symptoms, I suspect the switch may be stuck in boot mode or experiencing a hardware/software failure.
I would like assistance with a warranty replacement (RMA). I would prefer not to perform computer-based firmware recovery myself.
I also attempted to submit a support case directly, but the form requires a serial number. Unfortunately, the switch is strapped into the builder-installed networking cabinet, and I cannot access the serial number label without removing the equipment.
Please advise on the next steps for troubleshooting or obtaining a warranty replacement.
Thank you!
