Hi @MP
Based on the information provided, it appears that you are encountering issues after mistakenly resetting the RUCKUS Access Point.
To assist you further, could you please follow these steps:1. Disconnect the Ethernet cable from the affected AP that is currently connected to the RUCKUS ICX-7150-C12P switch port.2. Reconnect the Ethernet cable to one of the remaining 1-in-12 ports, as highlighted in the screenshot below.
After making this change, please observe the behavior of the AP if it works and let me know the results.
Thank you for your response.
Yes, please disconnect the affected AP from its current switch port and reconnect it to another available port within the 1–12 port range on the switch.
Also, could you please confirm whether you are trying to access Unleashed using the Unleashed mobile application or through the Unleashed web interface in a browser?
