Hello I am running r750 as master and i got h350 running on unleash for some reason they keep loosing heart beat I cant figure out why
ashish patel
909-322-7100
ashish@intechsytems.com
Dear Ashish,
Greetings.
Thank you for reaching out regarding the heartbeat connectivity issue between your R750 (Master AP) and H350 APs.
Based on the Unleashed behavior, a “heartbeat loss” indicates that the member AP is intermittently unable to communicate with the Master AP over the network. When this occurs, the AP may temporarily disconnect and attempt to rejoin the cluster.
Possible Causes:
Recommended Checks:
Next Steps:
If the issue persists,We request to create a support case via support portal and please share the following for further analysis:
We would be happy to review the logs and assist with identifying the exact root cause.
Best regards,Sunil AcharyaSenior Technical Support EngineerRuckus Networks
