Hi @Jbails7
Based on the information provided, it appears that you are encountering issues with RUCKUS ICX-7150-C12P Switch stuck in a boot loop.
If a hard reset of the switch does not resolve the issue, the next recommended step is to perform a software recovery on the Switch.
Please refer to the following RUCKUS Lennar Knowledge Base self-help article for detailed instructions on the recovery process:
/kb/articles/4-fixing-ruckus-switch-with-an-amber-orange-light-on-syst-green-light-on-pwr-no-lights-on-aps
Please follow the steps outlined in the article and let me know if you encounter any issues or need assistance at any point during the process.
Thank you.
Hi Imran,
I'm unable to perform a software recovery on the Switch. My laptop does not have an ethernet port. Any other suggestions?
Thanks,
Jeremy
If your laptop does not have a built-in Ethernet port, we recommend using an external Ethernet adapter (please refer to the screenshot below for an example).
Once you have the adapter connected, please proceed with the steps and let me know how it goes.
