Hi @GIGacilan11
Based on the troubleshooting performed, your ICX-7150-C12P Switch is not responding properly, and it is dead when checked with working power outlet.
As a result, this Switch unit appears to be defective and needs to be replaced through the RMA (Return Merchandise Authorization) process.
To initiate the replacement, Please use the private chat option to respond so we can proceed further. For your reference, I have included a screenshot below.
I’ve raised an RMA case and sent you a private message with the RMA details. You will receive further notifications from the RMA case.
Please check and let me know if you have any questions.
Thank you once again for your patience.
