Hi @Teamjoseph1991
I’ve raised an RMA case and sent you a private message with the RMA details. You will receive further notifications from the RMA case. Please check and let me know if you have any questions.
Thank you once again for your patience.
If your issue has been fully addressed, please click the Kudos button and mark the responses as an Accepted Solutions.
Based on the information provided, it appears that your RUCKUS devices are not working.
Please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
Help me with the requested query and should you have any further questions or concerns, feel free to reach out.
Could you please share a photo showing the current status of the lights, along with the full switch panel and all cable connections to the ports?
To upload the image, please ensure you are logged in to the RUCKUS Community Forums.
When replying on the forum, you should be able to drag and drop the image or browse your device to attach it. Please refer to the screenshot and link to your post below for guidance.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/My-Ruckus-system-not-working-no-lights-on-switch-nor-the-two/m-p/114226#M32019
Also, I tested the surge protector by plugging in a lamp with success so the surge is good. I also plugged the power cord (black) into another plug at the bottom of pic with green light with no success, but the lamp worked with the other plug.
So I think either the power cord is bad or the switch is dead. Unless there's a reboot method.
