Greetings,RUCKUS ICX 7150-C12P Switch does not power on.
I tried the recommended solution from "Process for performing a physical factory reset (hard reset) on the RUCKUS ICX-7150-C12P Switch" plenty of times. However, it did not resolve the issue.Please advise what needs to be done to make the switch work.Thank you.Lennar Resident
Hi @rpatel
I’ve raised an RMA case and sent you a private message with the RMA details. You will receive further notifications from the RMA case.
Please check and let me know if you have any questions.
Thank you once again for your patience.
If your issue has been fully addressed, please click the Kudos button and mark the responses as an Accepted Solutions.
If your RUCKUS ICX 7150-C12P switch isn’t powering on, first check the power cable, outlet, and any visible hardware issues. You can also try a different power source or adapter to rule out faults. In cases like troubleshooting steps similar to high speed rail in Australia small checks can make a big difference. If it still doesn’t turn on, contacting RUCKUS support or considering hardware replacement is recommended.
Hello Imran,
I appreciate the information you provided.
I've uploaded a video and an image for evidence.
Please let me know if additional information is needed.
Thank you!
Based on the troubleshooting performed, your ICX-7150-C12P Switch is not responding properly, when plugged to a working power outlet and it is dead. A hard reset was also attempted; however, the issue still persists.
As a result, this Switch unit appears to be defective and needs to be replaced through the RMA (Return Merchandise Authorization) process.
To initiate the replacement, Please use the private chat option to respond so we can proceed further. For your reference, I have included a screenshot below.
