Hello Community,
i decided to reuse some hardware that has been provided by a friend.
- 2 * AP zf7982 (indoor will be 4 at the end when all is installed)
- 1 * AP zf7782 (outdoor for happy gardening 🙂 )
as i recognized that i have issues by seting up the network // i thought it would be a good idea to invest in a zoneDirector
So i invested in a Zonedirector 1000 (and recognized afterwards that this was not the right model)
so i bought an additional ZoneDirector 1200.
Now i was sure that all will come to a goodent and i have the perfect networking infrastructure.
What should i say...
i have issues to get a stable network.
When i reset the zonedirector and start by scratch,
i only activate a "standard usage" Network)
With WPA2 and AES, autentication is open, no Mac filtering..
i het connection losses on moving in my house.
i can see the switch to another AP but it seems that the DHCP adress is not provided.
my clients have then diferent IP-Ranges
At the moment i do not tryy to do magic or any fancy security setup.
I am not living in a castle, so a belive it has to be possible to get thisrunning.
to be honest:
I have no clue what to do to get it up and running...
i was searching help in a german froum (because i am german) but i do not come to the end.
So can anybody give e a tip how to do an easy, stable setup?
I know i can not use the newest softwareVersion on the ZoneDirector, because when i do i will not be able using my "old" AP´s
so i am running at
- Version:10.0.1.0 build 146
