Could you please provide a detailed description of the issue you are experiencing, including any error messages you may be seeing? This will help us better understand the problem.
Additionally:
Hi @Cmi1883
Based on the information provided, it appears that you are encountering issues with RUCKUS Access Points with no power.
1. Were any power outages before the issue began?2. When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
Please provide responses to the queries from my previous post. This will help us move forward and resolve the issue as quickly as possible.
Thank you.
