I have received an E510 to extend the WIFI coverage outdoors. In addition to a power supply, the documentation indicates that I must also purchase an antenna module. Is this absolutely necessary or could I just add short antennas to the 2 antenna ports? It seems that the antenna module may be needed only if adding cables to run to a more remotely located antenna. Thanks in advance for your assistance.
