Hello @Bonoforgood
As per the case description, I understand that your RUCKUS setup is not working and having slow speed issues.
1. Was there any power outage before you started facing the issue?
2. Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
3. May I know how many access points are connected to the Switch?
Hello @Bonoforgood ,
Hi @Bonoforgood ,
Thank you.
Best regards,Pinky Rajendran
