Hi @Songbird52
Based on the information provided, it appears that you are encountering issues with the RUCKUS device.
1. Can you confirm if your RUCKUS setup was previously operational, and if there were any power outages before the issue began?2. When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
Please help me with the above queries and should you have any further questions or concerns, feel free to reach out.
Please confirm once uploaded in Google drive.
Thank you.
