Hi @Whitshines ,
As per the case description, I understand that your RUCKUS APs are not turning on after the power outage.
Also, you have performed reset on the Switch multiple times.
2. May I know how many Access Points are connected to the Switch? Also, please show the light status on the Access points too.
Hello my ICX-750~C12P is not working properly. no lead green lights to the ports after 25 resets attempts and waiting 20 minutes after each reset. No luck . No power.
Hello @Whitshines ,
From the response shared, I understand that there is no power on the RUCKUS Switch.
From the response you shared, I see that the lights are still blinking on the Switch, which means that the Switch is still stuck in the boot mode.
As the reset was not performed successfully, the only option is to perform Software recovery.
we need to perform a software recovery since it can be that the image flash is corrupted in basic words the unit is not able to boot up properly and need to re-install the image to boot up properly.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is in boot mode.( reset process and software recovery is explained in this article)
/kb/articles/4-fixing-ruckus-switch-with-an-amber-orange-light-on-syst-green-light-on-pwr-no-lights-on-aps
Please follow the steps mentioned in the article and mention the point where you are getting stuck. If you could share screenshot, we could look into the matter and assist you accordingly.
I understand that you are unable to perform Software recovery as you do not have Windows or Macbook.
Could you please confirm if you have access to a Windows laptop or if you can arrange a Windows laptop to complete the software recovery process?
The only option is to perform software recovery as the boot image might be corrupted and needs to install them.
