Neighbor and I are in Lennar homes. Need to know how to restart system after power outage..access points are either dark or one access point has 4/5 lights on while the other has 3/5 lights.
attached find the photos you requested
Hi @ChanUser
Based on the information provided, it appears that you are encountering issues with the RUCKUS devices after a power outage.
1. When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
2. Is your internet connection from the ISP stable and functioning? You can verify this by connecting to your local router's Wi-Fi or through an ethernet cable from the router to a laptop/PC.3. How many access points are currently connected to the switch? Please describe the status of the lights on the access points. Similarly, include a photo showing the access points' light status.
Please help me with the above queries and should you have any further questions or concerns, feel free to reach out.
Thank you.
I received 2 messages from you and tried to respond through my email.....I received the following message..Delivery Status Notification (Failure)....Ruckus-Community-No-Reply@mailer.ruckuswireless.com because the domain mailer.ruckuswireless.com could not be found...Unclear why this happened...I will take the photos requested and send them tomorrow. The problems that I have continue
Apologies for the inconvenience.
Please log into your RUCKUS Community Forum Account and post your queries from there or attach the pictures. Below are the screenshots.
Please help me with the queries and should you have any further questions or concerns, feel free to reach out.
Based on the picture of your RUCKUS ICX-7150-C12P Switch, the light status appears to be normal.
Please try unplugging the Access Points Ethernet cable from the current switch port and reconnect it to any other available port (1–12). (Refer to the screenshot below.)
Once done, please check if the Access Point functions as expected.
