My Ruckus switch has power but my access pints have no power and no lights on them...I cannot connect to the access points with any device...how do I fix this...
You could power up the AP using a DC adapter to make it not powering up. If the AP still does not power up you could open a support case with Ruckus Support for an RMA.
Hi @mgmimms
Based on the information provided, it appears that your RUCKUS Access Points have no power.
1. Can you confirm if your RUCKUS setup was previously operational, and if there were any power outages before the issue began?2. When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.Please log into your RUCKUS Account before uploading these photos/screenshots.
Please help me with the requested queries and should you have any further questions or concerns, feel free to reach out.
Hi @James
Thank you.
