Note: this is a Lennar Home setup.
One of my Ruckus Unleashed Access Point is dead, no lights no power. I was able to take it off the ceiling mount, to my surprise it only had an Ethernet connection, no sign of power supply. Does that mean it ran on battery for the last 4 years?
See 2 photos:
https://imgur.com/a/4NXu4sPI noticed it had a 120v outlet connector on the back so I use a 120v cable plug to see if jt would turn on, and it did, which means the battery on this one is dead?
How can I replace the battery? What type of battery? There’s a unique screw on the bottom holding the AP together but I don’t have a screwdriver head to use on it. Can I leave my 120v cable on to charge the battery if that’s even possible?
