Hi @VKPATEL Greetings!!!
Could you please let me know if this is a Lennar Home RUCKUS setup?
Please confirm.
Thank you again.
Hi @VKPATEL
Thank you for the confirmation and for reaching out to the RUCKUS Lennar Home Community.
Based on the information provided, it appears that you need assistance in setting up RUCKUS devices in your recently moved Lennar Homes, and you have already tried a factory reset of the Access Points with no luck.
1. When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
2. Is your internet connection from the ISP stable and functioning? You can verify this by connecting to your local router's Wi-Fi or through an Ethernet cable from the router to a laptop/PC.3. Please describe the status of the lights on the access points. Similarly, include a photo showing the access points' light status.
Please help me with the requested queries, and should you have any further questions or concerns, feel free to reach out.
Hello Imran, Thanks for your reply back.
That is Correct, need assistance in setting up RUCKUS devices in recently moved Lennar Homes, Please.
1) Lights that are ON on RUCKUS 7150 are : STAT, SYST, PWR. Photo showing the status of the lights and the full switch panel with cable connections to the switch port is being attached to this reply.
2) Internet connection from ISP is stable and functioning properly.
3) Attaching a photo showing the access Points' light status.
Also, i wanted to know if there is a faster way of service availble for this RUCKUS setup other than online forum. Please let me know.
Thank You, Imran
Access Point Light StatusFull Switch Panel with cable connectionsStatus of the Lights
Thank you.
