Can i get someone to send me all the instructions and what i need to download to re- install this 7150, the POE are not getting power
Hi @BILLYAZURDIA
Based on the information provided, it appears that you are encountering issues with the RUCKUS devices with PoE not working.
1. Can you confirm if your RUCKUS setup was previously operational, and if there were any power outages before the issue began?2. When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
Please help me with the requested queries, and should you have any further questions or concerns, feel free to reach out.
Thank you.
