No power to the box. No success after trying numerous reset attempts.
Hi @coolcardo ,
From the case description, I understand that your RUCKUS Switch is not turning on even after performing multiple resets.
Video has been uploaded. As you’ll see, when I plug in the power chord into an outlet it quickly turns on (Green lights) show for a second then goes off. I used an extension chord to try other outlets but yielded the same result. The primary outlet has power because other devices are plugged into the power strip and those too were tested with no power issues.
Thank you for sharing the requested VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up even after connecting it to working power outlet, and when plugged in, all lights are off. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
