Running Unleashed 200.18.x with auto-channel at 80MHz. I'm noticing that the system is selecting any of the four 20MHz channels as the primary, which has the potential for P/S OBSS interference. Is there a way to configure Unleashed (UI or CLI) to only use the lowest channel numbers as primary when using wide channels?
