When I unplug/plug in the light flashes green one time and then no power. I have tried various outlets, power cords, and also tried to reset and nothing works. It does the same thing every time with flashing green once and then shutting off, Is this fixable or does it need to be replaced?
Hi @jjfleck1
Thank you.
Imran,
I am still having the same issue, I had uploaded the photos and video to the link you provided. What is the status on your end?
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, its LEDs do not turn on. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists.
As a result, this Switch unit appears to be defective and needs to be replaced through the RMA (Return Merchandise Authorization) process.
To initiate the replacement, please contact us via chat using the link provided below in this post. Kindly copy the URL/link of this post and paste it in the chat along with the serial number of your RUCKUS Switch when prompted.
Please refer to the example screenshot below for guidance on how to copy and share the required information:
