I had a power outage yesterday and when the system came back up the Ruckus ICX7150 was showing intermittent internet connectivity, and I am unable to connect to it using the Unleashed app on my phone. When I console in with putty, I see this prompt "ICX7150-C12-Router", which indicates that it is in router mode. I attempted to reboot the Ruckus ICX7150 from the Primary, using the command "boot system flash primary yes" but during the boot process I see the error message "could not boot from primary, no valid image; trying to boot from secondary". Any assistance on how to proceed would be greatly appreciated.
I have included the results of the following three commands
show version
show flash
Doing a "show version" command I get the following result.
ICX7150-C12-Router>show version
Copyright (c) 2017 Ruckus Wireless, Inc. All rights reserved.
UNIT 1: compiled on Nov 20 2018 at 00:20:22 labeled as SPR08080d
(29819448 bytes) from Secondary SPR08080d.bin
SW: Version 08.0.80dT213
Compressed Boot-Monitor Image size = 786944, Version:10.1.14T225 (mnz10114)
Compiled on Thu Nov 15 12:59:22 2018
HW: Stackable ICX7150-C12-POE
Serial #:FEK3849Q4L4
Software Package: ICX7150_BASE_L3_SOFT_PACKAGE
Current License: 2X1G
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 26 minute(s) 10 second(s)
The system started at 01:10:46 GMT+00 Sat Jan 01 2000
The system : started=warm start reloaded=by "reload"Doing the "show flash" command I get the following result
ICX7150-C12-Router>show flash
Stack unit 1:
Compressed Pri Code size = 25968884, Version:08.0.80dT211 (SPS08080d.bin)
Compressed Sec Code size = 29819448, Version:08.0.80dT213 (SPR08080d.bin)
Code Flash Free Space = 1204985856
Doing the "boot system flash primary yes" command I get the following result.
ICX7150-C12-Router#boot system flash primary yes
T=29m46.8: Halt and reboot
Unmounting the External USB
We are in system resetCopy RAMFBackup is fine
[ 1853.070153] [BrcdSoftlockup]: sim_softwatchdog thread is detached on core=0
[ 1853.158022] Sent SIGTERM to all processes
[ 1853.224700] Sent SIGKILL to all processes
[ 1853.274466] reboot: Restarting system
[ 1853.319062] Asserting GHPIO[7] reset sequence from Kernel ...
Ruckus Wireless Bootloader: 10.1.14T225 (Nov 15 2018 - 04:59:18 -0800)
Booted from partition 2
DRAM: Validate Shmoo parameters stored in flash ..... OK
ICX7150-12 (POE), PVT1
SYS CPLD VER: 0x4 Released Ver: 0xa
device 0 offset 0x0, size 0xc0000
bootdelay: ===
Booting image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
6 ecc_errors after reading 18b8000:18b9800
iproc_nand_read_page returned 2
NAND read from offset 0 failed -22
0 bytes read: ERROR
## Loading kernel from FIT Image at 70000200 ...
Bad FIT kernel image format!
ERROR: can't get kernel image!
BOOTING image from Secondary
NAND read: device 0 offset 0x4000000, size 0x2000000
33554432 bytes read: OK
Using 'conf@1' configuration
Trying 'kernel@2' kernel subimage
Description: Ruckus Linux MN VER=08.0.80d
Type: Kernel Image
Compression: lzma compressed
Data Start: 0x70213ee8
Data Size: 2183909 Bytes = 2.1 MiB
Architecture: ARM
OS: Linux
Load Address: 0x61008000
Entry Point: 0x61008000
Hash algo: crc32
Hash value: 8ce6e75a
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: crc32
Verifying Hash Integrity ... crc32+ OK
## Loading ramdisk from FIT Image at 70000200 ...
Trying 'ramdisk@1' ramdisk subimage
Description: Ramdisk -rootfs
Type: RAMDisk Image
Data Start: 0x7042fb84
Data Size: 25423877 Bytes = 24.2 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00000000
Entry Point: 0x00000000
Hash algo: crc32
Hash value: 8b4b95a9
## Loading fdt from FIT Image at 70000200 ...
Trying 'fdt@3' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x7042d92c
Data Size: 8607 Bytes = 8.4 KiB
Architecture: ARM
Hash algo: crc32
Hash value: 6fc9a37b
Loading fdt from 0x7042d92c to 0x65008000
Booting using the fdt blob at 0x65008000
Uncompressing Kernel Image ... OK
Using Device Tree in place at 65008000, end 6500d19e
Starting kernel ...
booting with 4.4 kernel
PLATFORM MN
dd cmd: UBI
Config partition mounted
Resource partition is mounted!!
Kernel crashdump is disabled.
Backup is fine
dma_mem_base: 0x96000000, dma_mem_len: 0x8000000, warm_mem_base: 0x9f500000, warm_mem_len: 0xb00000
Creating TUN device
Starting TPM Infra
Group tss and User tss created
kernel.hostname = localhost
hostname set to localhost
Starting TCSD Daemon
TCSD Up and Running
Enabling time stamp.
Starting the FastIron.
USER=root
HOME=/
GCOV_PREFIX=/fast_iron
ethaddr=c0:c5:20:9e:dd:f4?
TERM=vt102
PATH=/sbin:/usr/sbin:/bin:/usr/bin
crashkernel=64M@0x70000000
ip=10.14.145.207:10.14.202.36::255.255.254.0:MN:eth0:off
SHELL=/bin/sh
PWD=/
i2c-0 i2c Broadcom iProc I2C adapter I2C adapter 2
i2c-1 i2c Broadcom iProc I2C adapter I2C adapter 2
FIPS Disabled:PORT NOT DISABLED
platform type 90
OS>
Loaded Image SPR08080d from Sec Built on (UTC): Tue Nov 20 08:25:44 2018
Enabling Console Logging
Applying factory defaults..
flash_file=0.
INFO: startup config data is not available, try to read from backup
INFO: startup config data in the backup area is not available
Hotplugger Daemon Initialized ..
External USB disk is not mounted or plugged in.
set_board_level: gi_board_type = 116[ 62.802289] linux-kernel-bde: map phys range 0x3200000-0x3240000 to 0xb0bc0000-0xb0c00000
[ 62.984451] linux-kernel-bde: map phys range 0x88100000-0x90100000 to 0xa8bc0000-0xb0bc0000
DMA pool size: 134217728
PHY Reset De-asserted
sw_pp_sdk_init:137 ToR init
SOC unit 0 attached to PCI device BCM56160_B0
Firmware version from File: 2.1.0
Pre Parsing Config Data ...
INFO: empty config data in the primary area, try to read from backup
INFO: empty config data in the backup area also
Done with Pre-allocating nexthop id's for Unicast & Openflow
Warning: This operation would close all existing SSH connection.
System initialization completed...console going online.
1024 MB DRAM
STACKID 1 system uptime is 8 second(s)
The system started at 01:41:53 GMT+00 Sat Jan 01 2000
ICX7150-C12 Router>
Error: Certificate is invalid
Info: Device certificate import is failed ..!!, ret: 21
ICX7150-C12 Router>
Creating certificate, please wait...
SSL Client Certificate is successfully created
PS 1, Internal Power supply detected.
PS 1, Internal Power supply is up.
PoE: Stack unit 1 PS 1, Internal Power supply with 124000 mwatts capacity is up
PoE Info: Adding new 54V capacity of 124000 mW, total capacity is 124000, total free capacity is 124000
PoE Info: PoE module 1 of Unit 1 on ports 1/1/1 to 1/1/12 detected. Initializing....
2000 log entries of PoE Event Trace Log Buffer is allocated on unit 1 for unit 1
PoE Event Trace Logging enabled for unit 1
PoE Info: PoE module 1 of Unit 1 initialization is done.
PoE: Power enabled on port 1/1/2.
TFTP session timed out
ICX7150-C12-Router>
