My Unleashed Ruckus has a Green light and an amber light. My AP will not power on even with a reset.
Hi @Nikkilee ,
From the case description, I understand that the status lights on the Switch is Amber and the PWR light is Green which means that the Switch is stuck in the boot mode.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is in boot mode.
/kb/articles/4-fixing-ruckus-switch-with-an-amber-orange-light-on-syst-green-light-on-pwr-no-lights-on-aps
Please follow the process as explained in the article and let me know if you have any queries in this regard.
Hello @Nikkilee ,
Yes the reboot did not work with powering on either reset . And I don’t have an Ethernet port on my computer is there another way ?
I understand that you have completed reset on the Switch.
As the reset was not performed successfully, the only option is to perform Software recovery.
Please note, you must use ethernet cable (both ends RJ45 plugs) and USB to type C cable both together for Software Recovery process as described in steps 2 & 3 in the guide link.
May I please know if you have an option to arrange a laptop with an Ethernet cable port to complete the software recovery process?
