Greetings all,
I was wondering if there are any tools in place to backup configurations from the R1 portal. I don't mean switch configs but rather settings on the portal itself such as Network setups etc.
Grateful for any insight, thanks!
Ethan
Ethan,Thank you for writing to us.I understand you want to perform a config backup on the Ruckus One Cloud. Unfortunately, we do not have an option to do so. Best Regards!Amith
Thank you for your response @Amith,Understood; as end users we don't have this option. Would I be correct in assuming that is something managed on your end? Say for example a user deletes something they shouldn't or in an extreme case something goes down on your end, you would be able to restore what is lost in most cases?
Thanks again!
