I have a Ruckus ICX7150-C12P-2X1G Switch installed in my Lennar home that recently stopped working. When I plug it in, the lights briefly turn on and then shut off completely. After that, the device does not power back on.
Here’s what I’ve tried so far:
Verified the power source (tested both PoE and direct power adapter);
Performed both hardware reset and factory reset procedures;
Disconnected and reconnected all cables;
Tried accessing the web interface via default IP, but the device does not appear on the network.
None of these steps worked. The behavior is consistent: lights turn on for and instantly goes off, and the unit becomes unresponsive. It seems like a hardware or something else.
Has anyone experienced something similar or have any additional troubleshooting suggestions? Otherwise, I believe I may need a replacement unit.
Thanks in advance!
