Does R500/R510 supports Wireless VLAN whiteout controller ?
I am thinking about installing a standalone R500/R510.
I need to know if it supports Wireless VLAN whiteout controller or not ?
I want to setup 3 different SSID and assign each SSID to a VLAN in my network.
martin_martin
Hi, Alfie,
You can either use the Unleashed software or the standalone 104.0.0.1347 software for this.
Kind regards
Maritin
could you please let me know if it is possible to change a R500 into R500 Unleashed by software or firmware change or I need to buy a R500 which is originally Unleashed ?
or if it is possible to change a regulare R500 software version into 104.0.0.1347 ?
or if it is possible to change a regular R500 software version into 104.0.0.1347 ?
martin_martin
Yes, just download the unleashed software, factory reset your AP and then via the webgui upload the unleashed software .
Kind regards
Martin
