I’m recovering a Ruckus ICX7150-C12P switch stuck in bootloader mode after a power outage. The system LED is solid amber, and no devices connected to it are powered.
Issue:
The bootloader looks for SPR08090d.bin via TFTP.
I set up a TFTP server on macOS serving files from /private/tftpboot.
I placed several firmware files there, including SPR08090f.bin renamed to SPR08090d.bin.
The TFTP transfer completes successfully, but the switch reports CRC mismatch or invalid image errors.
What I've tried:
Verified TFTP server and network settings.
Used multiple firmware versions (08.0.90f, 08.0.95g).
Renamed files to match bootloader expected names.
Ran update_primary SPR08090d.bin command multiple times.
All attempts result in CRC errors or incompatible image errors.
Request:
Confirmation of the exact firmware file needed for recovery.
Suggestions for recovery methods from this bootloader state.
Any official recovery firmware or tools available.
Advice on proceeding safely without risking device bricking.
Thank you
