Hi!
I have an R600 that the GUI is acting strange on. I cannot set the system name, it never saves, I cannot set the system time, I cannot restore from backup, and most importantly I cannot enable Mesh.
I had everything configured, and every time that I select to enable Mesh it hangs at processing and never completes, I let it sit for 30 minutes and it still never completed. I took a backup and did a factory reset to try to enable it from the wizard, I selected it and it did not apply. When I tried to restore the backup, it would let me browse and select the .bak, but would not give me the restore options. I have another AP (r500) that work and they see each other and respond properly normally, but I need to deploy the 500 in an area where there is no Ethernet accessible. Some other strange things I have noticed, the sync time from PC doesn't work (not really important if I can get NTP to work), and if I click the registration link it does not take me anywhere and locks up the GUI.
I have tried on Chrome and Edge, from 2 different machines.
I can try to SSH to it and see if I can enable it that way, I'm a cisco guy so I'm not afraid of the CLI, and I can figure out the commands if its possible to do from the CLI.
Any help will be appreciated.
Thanks!
