I use speedflex to test my ap, uplink speed is more than 1000Mbps, but downlink speed is less than 200Mbps, what is the reason? should I use another speed test tool?
Hi Yuqing,
Hope you are doing great!
Asymmetric speeds in SpeedFlex tests on our AP's, with uplink speed 1000 Mbps but low downlink <200 Mbps, are common and often not a problem.The difference between the uplink speed (more than 1000 Mbps) and the downlink speed (less than 200 Mbps) seen during the SpeedFlex test can happen for several reasons.
Possible Causes:
Recommendations:
zap.exe -r90 -s [source IP] -d [destination IP]
Replace the source and destination IP addresses with the IP's of the controller and AP.
Regards,Ashwin Mathiyazhagan
