Model: ICX 7150 has no power. I tried to recycle the power, tried different wall jack still no luck. Made sure wall jack is fine , it’s the Poe switch which is not powering up. Both AP’s and other smart home devices are all powered off due to this.
Hi @avinothcool
I have uploaded the video and photo. Additionally also uploaded the ruckus access point with no power due to the poe switch being down.
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting performed, it appears that your ICX-7150-C12P switch is not powering up. When plugged in, the device briefly flashes an amber light before going dark. You have confirmed that the switch is connected to a known working outlet/power source, yet the issue persists.
Given the circumstances, this switch unit should be processed for RMA (Return Merchandise Authorization), which essentially means it will be replaced.
Feel free to contact us via chat. Copy the link of this post (URL), and paste it into the chat when prompted for the unit replacement.
Please follow the steps as shown in the example below:
As shown in the picture below, copy the link and share it via chat from the link provided:
Hi Imran, I did contact chat support , it was completely BOT. It did not tell me if the RMA was credited. Ruckus Networks Support Case 01948710.
can you check the case and confirm the RMA has been created and when will I get the replacement , what’s the tracking no? We are without wireless and need this asap. Also is it just plugin or do I need to configure anything ? Can I remove the old and connect the new one ?
