hi admin...i got 10 ap in my block....right now all using same ssid wifi-staff..and wifi-student.....but how to i add another ssid nam wifi-guess on only 1 ap wifi on vsz controller ??
pls help
hi...pls help
Hi,You need to create a WLAN Group >> Add the WLAN >> Go to Access Point >> Edit the individual AP Config >> Under WLAN Group >> Select the WLAN Group you have created with specific SSID.If you want to broadcast on multiple APs:create AP Group and ADD APs to it.Then Assign the WLAN Group.
ok thnks....right now want only individual AP...for multiple AP i already know...i will reply later...thnks for info
