None of the LEDs located on the ICX 7150-C12P light up.
I have tried about 5-10 hard resets where I use a paperclip to push in the reset button then giving the switch power but I get 0 response.
I have also made sure that the outlet that I am using is working with other devices, and yet the Switch gives no response on the same outlet.
I recently moved into a Lennar home and am the (I believe) second owner. I'm not sure if my APs are in good health either. But I would like to sort out the un-responsive Switch out first.
Thank you!
