Red light then green light 5 times, repeat
I have the unleashed 550 and when i restart it it will work for 5 to 30 minutes. Then it drops and the network can not be discovered on a device. The AP will be red like its rebooting, blink green 5 times, then back to red. Each time i restart, it works briefly, then the problem occurs again.
Please inform what this red then 5 green pattern means.
Thanks,
Justin
stanley_zhou
what's Unleashed 550? we have no this mode. Which AP mode, and version you used?
sometime AP will reboot for power problem, whether the power is enough in your case?
Its a ZoneFlex R500 Access Point - Sorry for the confusion
Does that allow you to give a better answer?
