Hello,In order to make a proper installation for the T750SE, I need to know its dissipated power, knowing that it will be plugged in AC.I could use the consumption power, but If i can get a more precise number it will be better.
Thank you for contacting us via the RUCKUS Community Forum.
Could you please confirm if the power consumption information shared from the T750SE datasheet addresses your query?
Feel free to reach out if you need any further information.
Hi Edward,
No this isn't what I'm looking for.I got an answer from my supplier:
Thanks for the clarification.Appreciate the update — good to know the BTU rating for the T750 is 82.6 BTU/hr. That should help others who might be looking for the same spec.
Let me know if there's anything else you're trying to pin down — happy to assist if I can.
