Routing problem with R600 unleashed
My APs are not able to join any adress if they are not in the same subnet. The default gateway is correctely configured. If I put my laptop on the same subnet than the APs, it works.
My R600 are in version 200.4.9.13.17
AP's must be on the same layer 2 subnet.
stanley_zhou
Unleashed AP only can join into master in the same sub-net.
What's your laptop problem? I don't know: If I put my laptop on the same subnet than the APs, it works. --> So what's your key problem?
This is the answer. Unleashed APs must be in the same L2 subnets.
APs should be in the same L2 subnets, visit
Windows Defender Support
for more solution to such problems.
@michael_brado-
Please note that the "Windows Defender Support" link does not actually go to a Microsoft page, or an ESET one. The parent comment appears to be spam and probably should be removed.
