I'm seeing the same issue that was reported here:https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/ICX-7150-C12P-not-powering-on-no-status-lights/m-p/81731I have unplugged the Ruckus switch and when I plug it in all of the LED's light up for a split second and then go off. I have tried plugging the switch into several, good, power outlets and get the same results.
Hi @dbooth ,
From the case description, I understand that you the Switch is not turning on and the lights are off.
Hello @dbooth ,
Thank you for sharing the details in a private chat.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up even after connecting it to working power outlet, and when plugged in, all lights are off. However, the failure persists. This Switch unit should be RMA (Return Merchandise Authorization) in simple words replacing it.
