We have a Ruckus R510 in our lennar home but there is no light on it and it's not working. How do I get technical help for it?
Hi @sagarpatil352,
As per the case description, I understand that one of your APs are not showing any lights.
1) Was there any power outage before you started facing the issue?
2) On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
3) May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Hello @sagarpatil352 ,
Hi @sagarpatil352 ,
Thank you.
Best regards,Pinky Rajendran
