Hi Miked43,
Thank you for reaching out to RUCKUS via the Community Forum. To better understand your setup and assist you effectively, could you please provide the following information:
Your response will help us address your query promptly and accurately.
Vasanth Edward
Virtual Smartzone Version: 6.1.0.0.935Access Point Model: H510Ethernet Port for TV: LAN4Ethernet Port for Network Uplink: LAN5
Could you please execute the following commands on one of the Access Points (APs) for testing purposes?
set qos eth3 directed multicast disableset qos eth3 igmp-snooping disableset qos mld_query v2 disableset qos igmp_query v2 disableset qos igmp_query v3 disableset qos eth3 tos classify enableset qos tos classify video 40set qos tos mark video 40set rflow-offload disable
Once the commands have been executed, kindly share the output with us. Additionally, you may use the AP script following this link to implement the changes across all the APs in your network.
Did I answer your query? If yes, hit the Kudos button and also accept the answer asAccepted solution.
Regards,Vasanth EdwardCCNA || CWNA
Hi @miked43,
I am following up to check if the solution we shared has resolved the issue with your IPTV setup. Please let us know if the issue persists or if any further assistance is required.
