Phillips Hue - Connecting to IoT Controller
ali_db0udsohr2q
Contributor
So has anyone had any luck connecting a Phillips Hue Bridge to the IoT module?  Does it require any specific Plugin or should it connect without any plugins?
2 REPLIES 2
Ankush_Chandan
RUCKUS Team Member
Hi Ali,
If the Phillips Hue Bridge  supports Zigbee/ Zigbee 3.0 or BLE, it can be connected to our IoT module. Can you check the product specifications and confirm if it has that capabilities?
-Ankush
andrea_coppini
Contributor II
The Hue Bridge is an IOT gateway itself.  It does the same job as the Ruckus IOT module.
Are you thinking a Hue Bulb maybe?
