Client wifi capatibilies
aleksandar_radi
Hi Everybody. Does someone have a list of phones with data about wifi antenna confguration and capabilities? I am interested in device MIMO configuration (1x1:1, 2x2:2, etc). Thanks a lot.
4 REPLIES 4
igor_tunakin
Contributor
Hi Aleksandar,
There is a very good internet page with a plenty of information about client devices
https://clients.mikealbano.com/
I'm glad I was able to help
Igor
aleksandar_radi
Thanks Igor. I know this page, but it contains phones and devices mostly used in USA.
For example, Huawei, Honor, Xiaomi devices are not in list, but very videly used in my country.
However, thanks and regards.
igor_tunakin
Contributor
Well. You can also try to find technical reports and more technical information on the WEB page of the Federal Communications Commission (FCC):
https://fccid.io/
For example the FCC ID of the Huawei P8 is QISALE-L21 and here technical details about its radio modules:
https://fccid.io/QISALE-L21
Hope this helps!
aleksandar_radi
Hi Igor,
thank you very much, I think that this source can have right information I need.
I will check it immediatelly.
Once again, thank you very musc and kind regards,
Aleksandar
