CLI command to verify if I'm booted into the primary flash or secondary flash - Ruckus ICX 7450 ?
rahul_chakravar
Hi all, I'm new to ruckus devices and trying to get my head around the CLI commands, etc.
Is there a CLI command to verify which partition I'm booted into?
1 ACCEPTED SOLUTION
BenBeck
Hey there,
"Show version" will tell you. Look for the verbiage "from primary" or "from secondary". You can use "show flash" to see what is stored in each flash partition.
Ben Beck, RCNA, Principal Technical Support Engineer
2 REPLIES 2
BenBeck
Hey there,
mohammad_atmazi
Try this command
Image_ images_messages_61e7c67c3dc88b09f202d3fc_cd20e471f0ea5c4c912bbcce97ebb476_Capture-44793bbc-be8e-4d36-b5db-4d040cba48db-1829665601.PNG
